... | @@ -12,7 +12,7 @@ The following considers that you have a working installation of Lazart. The comp |
- [Instrumenting the code](#instrumenting-the-code)
- [Creating the analysis script](#creating-the-analysis-script)
- [Running your analysis](#running-your-analysis)
- [Going Further](#going-further)
- [Going further](#going-further)
# An example function: `verify_pin`
... | @@ -210,42 +210,69 @@ The module [`lazart.verify`](https://securitytools.gricad-pages.univ-grenoble-al |
You can now try your analysis by simply execute your script:
```console
```console
root@lazart:/opt/lazart/use-cases/examples/get-started# ./analysis.py -r -o=4 -V=quiet
root@lazart:/opt/lazart/use-cases/tutorials/tutorial-1-2# ./analysis.py -r -o=4 -V=quiet
Mutation file parsing ended. 0 warning(s) and 0 error(s) generated.
mutation file parsing ended. 0 warning(s) and 0 error(s) generated.
preprocessing starting.
preprocessing ended. 0 warning(s) and 0 error(s) generated.
mutation ended. 0 warning(s) and 0 error(s) generated.
module clean.
module clean.
module saved.
module saved.
Program: Full attacks results
Program:
| Name | Ins. | BRs | IPs | Dets | | Attacks | 0F | 1F | 2F | 3F | 4F | Total |
| unammed | 468 | 18 | 4 | 0 | | atk: | 0 | 3 | 8 | 12 | 9 | 32 |
| unnamed | 485 | 22 | 4 | 0 |
Attacks analysis: Execution:
Attacks analysis:
| Attacks | 0F | 1F | 2F | 3F | 4F | Total | | Trs | PP | IgT | KT | CP | EP | EI |
| atk: | 0 | 3 | 8 | 12 | 9 | 32 | | 32 | 44 | 2 | 34 | 32 | 76 | 8012 |
Hotspots: Time metrics:
Hotspots:
| Order | Info | 0-order | 1-order | 2-order | 3-order | 4-order | | TT | TLz | TDSE | TTr | TA |
| IP | | | | | | | |-------+-------+--------+-------+------|
|---------+-------------------+-----------+-----------+-----------+-----------+-----------| | 0.178 | 0.064 | 0.08 | 0.058 | 0 |
| IP | | | | | | |
| 0 | ti [l:9, bb:bb1] | 0 | 1 (mc:1) | 4 (mc:1) | 6 (mc:1) | 4 (mc:1) | +-------+-------+--------+-------+------+
| 1 | ti [l:10, bb:bb2] | 0 | 0 | 5 (mc:1) | 19 (mc:2) | 25 (mc:4) |
| 2 | ti [l:20, bb:bb7] | 0 | 1 (mc:1) | 0 | 0 | 0 | Coverage:
| 3 | ti [l:21, bb:bb8] | 0 | 1 (mc:1) | 7 (mc:1) | 11 (mc:1) | 7 (mc:1) | +-----+-----------+-----------+-------+-------+-------+
+---------+-------------------+-----------+-----------+-----------+-----------+-----------+ | S | ICov(%) | BCov(%) | ITr | FBr | PBr |
| 3 | ti [l:22, bb:precompare] | 0 | 1 (mc:1) | 7 (mc:1) | 11 (mc:1) | 7 (mc:1) |
| ok | 97.86 | 88.89 | err | 14 | 4 |
Execution:
| 32 | 44 | 2 | 34 | 32 | 76 | 7637 |
Time metrics:
| 0.236 | 0.069 | 0.14 | 0.062 | 0 |
Coverage:
| ok | 88.87 | 68.18 | 32 | 12 | 6 |
verify: attacks tests passed
verify: traces tests passed
root@lazart:/opt/lazart/use-cases/examples/get-started/#
In this example, the analysis was run with quiet verbosity mode (`-V=quiet`), forcing the re-computation of each step despite any cached results (`-r`).
